Displays advertised LDP LSP implicit-null label information.
| ipNetmask | Specifies an IP network mask. |
N/A.
If no options are specified, tabular information for all LDP advertised implicit-null labels is displayed. The following table describes the display fields that appear when this command is entered.
| Field | Definition |
| Advertised Label | Advertised Label is the label advertised to other routers. |
| Destination Mapping | Destination Mapping displays the destination IP address and mask. |
| LSP Flags | LSP Flags lists the flags for each label, which are described in the key at the bottom of the display. |
| Peer Label | The peer label that replaces the received label of incoming packets during a label swap on a transit LSP. The peer label appears only for transit LSPs. |
| NHop Type |
                                 NHop Type helps define the handling of a packet arriving with the specified advertised label. Possible values are: IP—The label on the packet is swapped and the packet forwarded to the IP address shown in the NextHop field.vlan—The label on the packet is stripped and is IP routed according to the Destination Mapping field.locl—Indicates that the tunnel destination is local to this switch.  |
| Next Hop | Displays an interface ID for the next hop router, which can be a VLAN name, VMAN name, or IP address. |
| Name | Displays a VPLS or LSP name. |
| Received Label | Received Label displays the label received from other routers. |
The following command displays all advertised LDP implicit-null labels:
* Switch.1 # show mpls ldp label advertised implicit-null
This command was first available in ExtremeXOS 12.5.
This command is available only on the platforms that support MPLS as described in in the Switch Engine v33.1.1 Licensing Guide document.
